This is the second time i've posted about this, but I have a bit more information this time. When I play back some divx files, especially the ones that are split in two files and are still in theatres, there is a problem with the tint, it gradually goes to a bright pink and then suddenly cuts off to the normal colour. I thought I fixed this problem because when I play back DVD rips in divx format there was no problem. This problem also carries over to any typre of converter I try it on. But it only happens with those cam movies, I think it is very strange. Whats even stranger is this problem is gone when I use windows media player 6.4, but anything else and the tint is all screwed up. This is a problem for me because I just want to convert and burn it, but i can't if it goes bright pink every few seconds. This problem first arose when I upgraded to windows xp build 2481. Any input at all is greatly appricated.
Hi I saw in this forum..If you installed the Angel codec you got these purpur effects on videos. Install another codec and it's gone. I had the same problems.But its gone now.
DVD player can't read large DIVX files
By Alistair George in forum Authoring (DVD)Replies: 14Last Post: 27th Jan 2009, 18:16 -
DivX v/s Xvid trial and error now puzzled, read toward end
By adiktlost in forum Newbie / General discussionsReplies: 7Last Post: 12th Jan 2009, 20:37 -
It's possible to change a DVD player to read DIVX?
By psouza in forum Newbie / General discussionsReplies: 4Last Post: 27th Jun 2008, 14:11 -
Help Friend! How to read subtitle file on my dvd player (not divx supported
By justin1983 in forum SubtitleReplies: 17Last Post: 26th Jan 2008, 11:42 -
Hack to convert USB/DIVX DVD player to read from the Network
By thrutnut in forum DVD & Blu-ray PlayersReplies: 8Last Post: 21st May 2007, 11:27
