My computer has been setup with TEMPGENC plus and DIVX codec 5.1. TEMPGEnc in the past have flawlessly converted any DIVX/XVID avi files fine. But then I've got the new MASTERandCommanderofTheFarSide.avi and TEMPGENc was unable to convert/preview the movie to mpg, but the sound was detected fine. I checked the avi file using GSpot and it showed that the avi file format is DIVX 5.0 . What's exactly is wrong with the avi file and how can it be fix so that I could converted to a mpg file/DVD file. That's all I need. Can this avi file be demux .??? Thanks![]()
I wasn't aware that was out on dvd yet
. Try opening it in VirtualDub and if you can see it there try doing a bad frame check and fix bad frames, demux, or, if those don't work, try to frameserve to tmpg from virtualdub or avisynth.
DivX3 to DivX5 or XviD?
By Ogilvy in forum Video ConversionReplies: 5Last Post: 13th Dec 2013, 19:24 -
Which video players can handle DivX5 files the best?
By True Colors in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2011, 11:06 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
DIVX 3 to DIVX5
By munozsblazer in forum Newbie / General discussionsReplies: 13Last Post: 9th Mar 2008, 12:05
master&commander NOT available t public ..ergo
WAREZ...
