Hi folks... I've been wrestling with this issue for a while now and I'm about to lose whats left of my mind. Hope someone can help... TMPGEnc won't seem to batch projects that take a long time.
I load up my first AVI and WAV for conversion, set up the template for SVCD, and save it all as a project (tpr) file. I do the same with the second AVI and WAV and save another tpr file.
I then clear the projects, invoke the batch encoder, and add my newly created projects to the list. I save the list and then press the 'Run' button and go away. When I get back to the system, TMPGEnc is no longer running and only the first project has been completed.
Some points:
I do not check the 'shut down after finish encoding' checkbox. I've tested this with tiny files and it seems to work. Long encodes seem to be the problem and it's not just 12h that has done this to me.
Any ideas? I'd really like to set up a couple of days worth of pojects to encode and then just leave it alone.
I'll give settings details if anyone thinks they're relevant.
_________________
Varek
Electonics Engineering Technologist
Web Application Developer
Videographer Wannabe
<font size=-1>[ This Message was edited by: Varek on 2001-07-10 09:03:40 ]</font>
Hi,
I'm still having this problem and would really appreciate some help.
I've now tried this with converting a group of 7 10min avi files with Sefy's SeVCD template. I load up each file with the template, do the settings, and save the project. Once all 7 projects files are created I create a batch job file, add all the project files, save the batch job file, and hit RUN.
Each encode takes about 30mins. And at the end of encoding the first file on the batch list - TMPGEnc just goes away right before my eyes.
Looking at the log files for the encode I notice that they don't have the little summary at the end. In fact the last two files stopped 35 and 29 frames before the end. They still play fine as this many frames is only about a second.
Is anyone using TMPGEnc's batch encoding sucessfully? Any suggestions would contribute to my sanity and just generally be appreciated.
Thank you.
Varek
Videographer Wannabe -
Hello. I have used Tmpegenc's batch encode thingy muliple times and it has worked flawlessly. I usually do the "add current project to batch list" rather than making a project and then saving it.
Yup! That seems to be working so far... Using the "add current project to batch list" and then MPEG file right?
I guess it doesn't like it when you create the batch list manually? Oh well... I'll see if this works with the bigger stuff.
Thanx so much!
Varek
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 00:00 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 20:52 -
TMPGEnc Plus won't complete batch jobs.
By Timex in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 23:13 -
Slight problem when hardsubbing in a batch
By bmwracer in forum Video ConversionReplies: 1Last Post: 25th Jun 2007, 17:32
