I've got a proline as well and have got the same problem. I use Pinnacle DV studio to produce the MPEG with the VideoCD template and then use Nero5 to burn the CD again with the VCD template. When I put the disc in the Proline it just says No Disc. Did you ever get a resolution to this ? I've read the Proline manual and although it does play VCD 1 & 2 it does specifically say don't use CDRs in it - I wonder if this is the problem as Nero can somehow tell between CDR & CDRW even on a blank disc - magic number pre-recorded maybe ?
Regards Mark
On 2001-05-27 12:43:28, smallscreen wrote:
I'm in the UK and am working with PAL footage - I need to transfer some dv footage to vcd, but despite reading all the tutorials, I'm still stuck.
I'm running Premiere 5, with plug-ins for both Megapeg MPEG1 and Minerva Impressions MPEG2, and can't get either of them to provide a VCD.
What files are needed on a vcd disc? Just a .mpg file or any other launcher files?
I use adaptec easy cd to burn, although minerva can also burn straight from the program. Presumably I create just one data track?
My standalone DVD player (proline) does play VCDs, as I watched a vcd movie on it a while back.
I've tried setting frame rate, resolution etc. as in the tutorials but its still not working!!
What am I doing wrong? I'm getting very confused, the more I read.
Many thanks in advance
Anthony
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Are you burning the files as ISO or as VCD? You can't burn as ISO with just the MPG file on, there's a byunch of other fiels in certain directories that needs tp be on there... but don't wory about that. Use Neor 5.0 or higher and chose to burn a VCD! If you saved the file as MPEG-1 in Premiere it's nothing wrong with the file!
Thanx/
Lars
Help needed with .mts avchd panasonic files
By zapster in forum Video ConversionReplies: 10Last Post: 23rd Mar 2012, 11:08 -
Urgent Help needed: all video converters corrupt my mp4 files, accelerating
By marilia05 in forum Newbie / General discussionsReplies: 4Last Post: 6th Apr 2011, 06:50 -
problem to download certain files from rapidshare- help needed
By deejay.2001 in forum ComputerReplies: 3Last Post: 25th May 2009, 05:52 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 01:30 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
