I'm looking for recommendations for how to label my DVDs (wedding videos and old home movies) before I send them to family for X-mas. I did a search and people talk about 'metal foil' labels but I can't seem to find these at Best Buy et.al.
Can some kind soul recommend a name/brand. Thanks in advance.
Use a Sharpie....and save the fancy stuff for the covers. You can't see the DVD while it is playing OR when it is on the shelf next to the other DVD's in their cases...
Hub labels. For when you care enough to send the very best!
Hello. -
Get one of those TDK disc printers for £70 and print directly onto the disc. Looks professional, won't rub off, won't damage the disc, and only takes 8 seconds!!
tommyknocker- this: https://www.videohelp.com/forum/images/guides/p735282/xxguide21.JPG is TIGHT!!!....how did you do it?
Those are hub labels from from Surething. You make them, print them out, and apply them with an applicator, just like the large ones. Click here.
Hello.
Longevity of Standard DVDs and BluRay DVDs
By bmccollum in forum MediaReplies: 10Last Post: 20th Oct 2010, 19:32 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
HELP! Too Much Text - I Need Labelling Template For Text
By kasius in forum MediaReplies: 5Last Post: 6th Dec 2008, 17:08 -
Best methods of labelling DVDR's, please.
By StuR in forum Authoring (DVD)Replies: 14Last Post: 24th Jan 2008, 13:07 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 10:02
