Just wanted to hear which route you would take??? I went with a DVD Recorder, but I may be re-thinking my decision. I went with the DVD Recorder to save myself time. It turns out that I probably still monkey with my DVD Recorder captures just as much as I did with my capture card (mainly because the menus really suck). My situation is simple, ADVC100 or DVD Recorder??? My capture card recently went out, and i need a new solution. The ADVC100 sounds good due to the fact that it takes most of your system restraints out of the loop...with the exception of hard drive space. My old capture card did a good job, but the speed of my system was always an issue. (P4 1.6 - 512RDRAM)
Don't get me wrong...My Cyberhome 1500 DVD Recorder has been solid as far capture quality goes! The menus just leave a little to be desired.
Anyhow...Let me know what you all think. 8)
Thanks,
gpwake!
Results 1 to 1 of 1
canopus advc100 problems--any suggestions?
By esek64 in forum Video ConversionReplies: 3Last Post: 14th Aug 2010, 03:26 -
Fuzzy Video using ADVC100
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 16th Jun 2009, 01:17 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
