Howdy, just converted to mpeg2, using the guide for tmpge.
got nero ultra tried to burn to dvd-no dice. indicated I needed
to buy mpeg-2/dvd plug in. WHAT DO I need to burn this mpeg2 to dvd disk? It's 3.06 gb. Using NEC dvd rw 1300a.
If you are creating a DVD for playing in your DVD player then you need to author your disk, then burn. There is a convenient section called Author right over there <-<-<-.
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 17:25 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
cannot burn or copy captured mpeg2 files
By DirtBikeMike in forum Capturing and VCRReplies: 12Last Post: 3rd May 2011, 08:49 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 15:18
