If so, What Media have u tried and tested.
Ive reported that Burnstar DISCS dont work very well.
they are very very cheap snide 65p each discs but when they burn not many dvd players can read them so dont even bother.
I have a 106D and have had lots of success with TYG01 (Fuji DVD-R) and RITEKG04 (TDK DVD-R). I had lots of problems with MXLRG01 (TDK DVD-R) but many others say that Maxell's are great so it may have been a bad batch I had.
-Darryl -
TESTED:
INFINITI DVD-R 1x Work FINE
BURNSTAR DVD-R 2x NOT VERY GOOD
WHITE TOP UNBRANDED 2x WORK FINE
I won't use dirt cheap media so I am not sure on those others. You're best bet is to get a program like DVDInfoPro to read the media codes since any DVD could be made by just about any company. It is the media code that really matters and not what is stamped on it or what packaging it is in. The Media list here at DVDRHELP.com has lots of information once you get media codes of the discs you try.
-Darryl -
I have a 106D and a 106RD (made for the far east) cheap disks I use are Datawrite 4x yellow and Bulkpaq 4x orange had no problems with either (apart from a bad lot of bulkpaq) and I always burn at 4x speed. Both writers have the latest firmware installed.
life's a shit sandwich and everydays a bite -
as long as you use good media you will have no problems
i always buy Ritek 03 or 04 there the best for playing dvd movies
in home dvd player.
:P
Pioneer DV-420V
By Vasilii in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Jun 2009, 08:28 -
Pioneer DV-410
By geroglifico in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th May 2009, 05:08 -
Pioneer 531H
By cscasto in forum DVD & Blu-ray RecordersReplies: 4Last Post: 6th Nov 2008, 21:19 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Pioneer 106D & Maxell 8x DVD-R
By piano632 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd Jun 2007, 18:38
