Hi all,
I've got DV AVI captured using Premiere 6.0 from my camcorder.
I used VirtualDub to extract the audio into a WAV file @ 48000Hz.
I then used ffmpeg (latest version) and the GUI (nice one Baldrick - much easier than Be Sweet and all it's dll's) to convert to 192kbps AC3.
The AC3 file plays just fine in Windows Media Player. AVICodec states I have the following AC3 codec installed:
"0x2000;AC-3 ACM Decompressor;0.4 .0;AC3ACM"
However, when I use it as the audio in TMPGEnc DVD Author, when viewing / playing the frames there is no audio. The WAV file works OK.
I tried the same AC3 file with WinDVD Platinum 5 and still no audio.
I burnt the DVD (to DVD-RW) anyway, just in case, and the audio was perfect and in sync. Weird.
Anyone know why the lack of audio on the TMPGEnc DVD Author and WinDVD occurred?
If you need any more info, let me know and I'll provide it.
Cheers.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I believe TMPEnc DVD Author just allows it to "pass thru" it does not actually support or encode it, thus it will not play as you view the frames.
Hope this helps -
Originally Posted by Turtle49Want my help? Ask here! (not via PM!)
a related question...
i try to compile 2 short DVDs into one dvdr in TMPGEnc DVD Author to create menus/chapter points. when i load up the first movie TDA tells me there is no audio. there clearly is audio on the DVD! i load up the 2nd movie and everything is fine.
i have not actually created an output from TDA cuz i'm afraid i won't get audio with my first movie. maybe after reading this i will go ahead and run the movies thru TDA and burn to rw.
anyone else have this problem? thanks for this post. -
Turtle49 and Lordsmurf - Thanks for the prompt responses. Much appreciated.
If it's just a "feature" of TDA, then so be it - A bit of a pain if you're trying to set chapters by sound rather than sight, but I guess that can be done using the WAV and then put the AC3 file in as the audio source later.
Any idea why WinDVD does it? I'd be surprised if it's the same...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Split, join, create silence of an ac3 file
By phate89 in forum AudioReplies: 6Last Post: 16th Jul 2011, 13:34 -
Long silence in ac3 is mysteriously shortened when I author
By Genaugmen in forum Authoring (DVD)Replies: 0Last Post: 20th Aug 2010, 16:47 -
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 22:03 -
TMPGEnc DVD Author 3 & Overscan
By heyjjjaded in forum Authoring (DVD)Replies: 4Last Post: 11th Aug 2008, 01:24 -
TMPGEnc DVD Author & Dolby 5.1 Digital Sound - Can it be Done??????
By Sparehead01 in forum EditingReplies: 2Last Post: 28th Dec 2007, 14:53
