I used the latest DVDlab 1.3 and are experiencing mpv ac3 out of sync problem.
I do not have this problem before.
The original mpv mp2 file looks in sync, but then when I convert the mp2 to ac3 and create the DVD, it looks in sync on the computer but out of sync on my pioneer standalone player.
Is it some setting I need to change? or is it a bug in the latest version?
Just a thought try converting yor audio to wav first then to ac3, I had a similler problem. Ding the audio this way worked 4 me.
How did you do the VIDEO encoding?
I only ever used DVD-Lab once and got audio sync problems so I decided NOT to register it since two other authoring programs worked with the same files and when I say worked I mean no audio sync problems.
I latter found out that the "problem" might have been the way I encoded the video.
I was doing a NTSC capture that was telecined so I did IVTC on it and encoded it as 23.976fps progressive in TMPGEnc. I did the IVTC in AviSynth so upon loading the AVS file into TMPGEnc it saw the file (properly) as being progressive and set it self up to do a non-interlaced encode with 3:2 pulldown.
And that I think was the problem. My understanding is that DVD-Lab does not like the way TMPGEnc does 3:2 pulldown.
So you have to encode as straight 23.976fps then run PULLDOWN.EXE on it afterwards (which is normal with CCE and can be done with TMPGEnc).
I never tried because my trail period ran out but based on othre user comments that most likely was the problem.
I use TMPGEnc DVD Author now which I registered and I am rather happy with it
DVD Lab Pro Audio Problems
By Outcast212 in forum Newbie / General discussionsReplies: 6Last Post: 21st Feb 2009, 02:11 -
DVD Lab Pro - Using VOBs, Audio Problems
By teacozie in forum Authoring (DVD)Replies: 5Last Post: 24th Sep 2008, 01:12 -
"Play All" caused audio out of sync (DVD Lab Studio, Half-D1)
By iryu in forum Authoring (DVD)Replies: 5Last Post: 21st May 2008, 01:52 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00 -
DVD Lab Pro audio is out of sync after compiling
By GangstaRap in forum Authoring (DVD)Replies: 5Last Post: 8th May 2007, 04:46
