  1. I have Unrared a file and it has produced a .MDS and .ISO file pair which I know needs to be burnt to DVD.
    How do I do this..?
    I have Toast 6.0 and Disk Copy which came with OSX.
    Neither seems to be able to mount or recognise the files, what other applications do I need and how would I use them...?
    Mar 2003
    How do I do this..?
    Well .mds is an alchol 120% image if I am not mistaken
    And .iso could be nero, disk juggler or a few other programs
    Dont know if a mac can burn a .mds file gumby has a conversion program that might work I am not for sure.
    Dont now why when you extracted the files that it gave you 2 different type of image files
    However a mac can burn a .iso file
    Go to the 4th window in toast that says "other"
    Left click and Select "disk image"
    Drag .iso file to disk image window
    Choose record
  3. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    What size are both files? For this ISO, you can put Toast 6 in Disc Copy mode, and choose Image File in the left side drawer. I have no idea about the other file, but I guess you can hope it's insignificant, or you might need a Windows machine to burn it, or at least convert it to a better format.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
