Hi everyone,
I have an .ogm file that I would like to turn into a quicktime formatted movie. My file does play with mplayer. I have read that if mplayer will play the file, you can encode it to this format with mencoder, but I don't know what to type into terminal to get the encode to work. Could someone please tell me the necessary input into mencoder is to make this conversion?
Thanks,
wolfwood87
AnonymousGuest
can you encode it w/ffmpeg?
If you use ffmpegX then you don't need to enter any code. If you specifically want to use mencoder in command line mode, check mencoder documentation at http://www.mplayerhq.hu/DOCS/HTML/en/
Major,
So using FFMPEGX I can go from .ogm to .avi without any formats in between? I am assuming that I would just need to use a DivX preset, so do you have any suggestions regarding whether to use the libavc preset of the fast DivX preset? What is the difference between the two exactly?
Thanks very much,
wolfwood87
converting quicktime format
By nospam7676 in forum EditingReplies: 11Last Post: 8th Mar 2010, 19:45 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Problem with QuickTime - DV Format
By parisisal in forum Software PlayingReplies: 3Last Post: 10th Mar 2009, 09:56 -
DV to a format that play in QuickTime and standaloneDVDplayer with chapters
By DavidCasillas in forum MacReplies: 3Last Post: 20th Sep 2008, 21:28 -
Dual Audio .OGM format to MPEG4
By Van Klizzy in forum Video ConversionReplies: 4Last Post: 29th Jun 2007, 23:50
