Hi!
My standalone DVD player should be able to play Mpegs / VCDs. Some it plays perfectly, others it has problems with the picture breaking up horribly. The mpegs / VCDs have been sourced off the newsgroups or converted from AVIs using instructions here. They all play OK on my PC with power DVD.
I am struggling to figure out what is the problem. I'm in the UK so everything here is PAL, but the setup SHOULD be able to handle NTSC. I can't find any software which tells me anything about the bit rate (is that the right term) or validity of the mpeg file - is there anything available? The media seems OK (I've tried a variety with no obviosu patterns.) Is there something obvious I'm missing?
Kev
Have you tried lowering the burn speed ?
Hi!
I've dropped the burn speed to the slowest my writer supports (4x) with no joy.Is there anything else I ought to check for? VirtualDub can take an AVI file and check that for errors - is there anything similar for mpegs?
Kev -
Well you say they play ok on your PC so its not the files themselves. Seems like you may have some bad media, try another batch/brand and see if that cures the problem.
Are you burning as VCD or raw mpeg, could be that the bitrate of the mpeg is too high if you are not creating standard VCD (although this would tend to cause stuttering rather than picture breakup). Virtualdub will tell you the bitrate. -
Thanks - I'll try a different brand.
VirtualDUB fails to load the mpeg file with the error "MPEG Import filter: pack synchronization error". -
sounds like an mpeg2 then, try virtualdub mod
DVD playing in standalone player but not on PC
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2008, 09:35 -
playing mpegs on a dvd player
By fromunda kid in forum Video ConversionReplies: 8Last Post: 9th Mar 2008, 12:30 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 13:16 -
playing avi file with subtitle in standalone divx player
By weeleong87 in forum SubtitleReplies: 19Last Post: 16th May 2007, 18:32 -
Problem with playing DVD in standalone player
By tngolfn in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2007, 17:41
