Does anyone here know a program which will change a PAL .VOB file to NTSC, and do the same for NTSC to PAL?
Thanks.
TMPGEnc Plus , Check the guides on the right. The easiest way I've found is to frameserve it to TMPGEnc plus using virtualdubmod.
Hope this helps
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
What is best way to convert vob files from pal to ntsc and vice versa?
By hibbs in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2010, 20:41 -
authoring PAL DVD using "mpeg-4 avc" NTSC 1280x720 VOB files
By ah76 in forum Authoring (Blu-ray)Replies: 14Last Post: 31st Oct 2009, 10:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
