I've got two AVI files to join together. They are XviD/AC3 and they overlap slightly, such that I need to cut a bit off one of them to get a seemless join.
I have done this already with VirtualDub using the Append AVI segment option but it produces a very loud full level high pitched noise just at the join point.
Is there a way to do as described without getting the noise at the join?
Thanks but I got around the problem another way. I encoded the two AVIs I had separately with one of them cropped down to the point where they were to join seemlessly and then I joined the resulting MPEG-2 streams together with the TMPGEnc MPEG Tools.
The final result is not absolutely perfect because the sound does disappear just for a fraction of a second at the join point, but it's a hell of a lot better than it was by trying to join the AVIs together before encoding.
Fortunately the join is at a scene change and there is no dialog at that point, so the loss of sound is almost undetectable.
Join 2 AVIs
By phunkidude in forum MacReplies: 2Last Post: 23rd Dec 2010, 14:28 -
How do I join avis of different dimensions together? Or add borders?
By thedarkness in forum Newbie / General discussionsReplies: 9Last Post: 24th Jul 2010, 18:19 -
Trouble joining two mp4s (or two avis)
By nosillacast in forum EditingReplies: 2Last Post: 27th Sep 2007, 09:30 -
How do i join 2 AVIs with different resolutions?
By chocolate_brownie in forum EditingReplies: 7Last Post: 31st Jul 2007, 12:37 -
How can I join several AVIs into one?
By htp367 in forum EditingReplies: 2Last Post: 30th May 2007, 10:06
