Hi all. I'm currently adding subtitles by frameserving...
But it seems that I always end up with a huge size of video although it is a 28 mins anime.. i did load up the vcd template but its always more than 600MB.. So, anybody knows how to reduce the size??
Any help is appreciated..
Thx..
28 min VCD should equal about 280 MB mpg. And you say you're using the VCD template without any modifications?
/Mats -
VCD is a very strict standard. All the gory details can be found top left (WHAT IS - VCD). The easiest way to encode to VCD specs is to use one of the VCD templates/wizards in TMPGEnc.
/Mats
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 14:31 -
Need help adding a subtitle to a DVD.
By chris4556 in forum Newbie / General discussionsReplies: 7Last Post: 24th May 2011, 22:12 -
adding watermark as a subtitle
By zammil in forum SubtitleReplies: 8Last Post: 20th Nov 2010, 01:45 -
adding subtitle
By Rezadarius in forum ffmpegX general discussionReplies: 1Last Post: 9th Aug 2008, 05:45 -
Adding a subtitle for a DVDR
By rotchild in forum SubtitleReplies: 5Last Post: 28th Jan 2008, 12:07
so can u tell me wats the ideal specifications for it??
