I used to use DVD Shrink 1.03 to shrink my VTS files that where to big to burn to DVD. About a week ago I started using DVD Shrink 3.0 beta 5. I liked this one a lot more because you can use deep analysis to make your movie look better once you compress it. The problem is, if I where to take an MPEG-2 file, and make VTS files of it to burn to dvd with TMPGEnc, I get an error that stays, Cannot decrypt VOBS The Reason Is Unknown. This does no happen when I try and open files from a REAL DVD ( one from the store) or when I use 1.03. How do I fix this?
need to check out them there guides
what you are referring to is....authoring... -
Go to this site, it is the site DVDShrink moderates so I assume it's the official DVDShrink site...lotsa answers there if you cannot find them here.
http://forum.digital-digest.com/forumdisplay.php?forumid=48 -
Iwas having this same problem and downloaded the 2.3 (non-beta) version of DVD Shrink. It does not have the deep analysis but does still produce good results. In short use 3.0 beta5 when it works and 2.3 when it doesn't.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
