Can I use dvd decrypter to burn a backup of dvd after I have reauthored in dvd shrink?
DVD Decrypter burns image files so you would have to create an image file of your output folder from DVD Shrink (VIDEO_TS)
a little guide on how to create an image , I found this the other day
Vejita-sama
Posted: 08 Dec, 2003 08:16
IMG Tools (classic) d/load here or at http://www.doom9.org
What I normally do is:
1) Make a folder (eg. burnme)
2) Place VIDEO_TS folder folder (as sub-folder)
3) Make a AUDIO_TS folder
4) Point to my root dir (burnme) then generate ISO image
I then burn with DVD Decrypter. Works great no coasters to date. -
Or you could try AutoshrinkISO, it lets DVDshrink use DVD Decrypter and simplifies the whole process.
I was a little confused on how auto shrink worked. Do I reauthor first, or do I just open up auto shrink.
Also, are there any alternative programs that will burn the reauthored dvd file from dvd shrink. -
AutoshrinkISO is just a front end to DVDshrink. It simplifies the process. It basically opens DVDshrink, where you choose your options. Then after DVDshrink is done, it uses the free program DVDDecrypter to burn your files to DVD. The real advantage is simplicity and free programs. You still have all the options in DVDshrink to use.
Now, do you lose any quality when converting the ripped dvd file on your hd to an iso file so dvd decrypter can burn it.
I was just a little hesitant on converting to an iso file.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
Ripping with SHRINK then BURNING with IMG burn
By efiste2 in forum DVD RippingReplies: 10Last Post: 17th Apr 2010, 00:39 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
burning with dvd shrink/imgburn
By angryassdrummer in forum Authoring (DVD)Replies: 4Last Post: 7th May 2007, 15:44
