I am suppose to recieve my dvd burner tomorrow. Pioneer dvr106, I am going to get it bulk with no cables. This is my first dvd burner and I don't know wheter I need any special kind of cable for it, or the same as a cd burner?![]()
YesOriginally Posted by slimmx
I don't know about Pioneer, but Sony recommends the use of an 80 wire IDE cable with their DVD burners.
If your motherboard supports ATA100 cables (the connection on the motherboard is blue) you should use an ATA-compatable cable (it has blue ends on it).
Yeah I got ata100. So I am going to use the regular cable I got right now then. Thanks to all for help.
regular cables will work just fine, but I guess there is something special about the blue ones...
Grounded all 40 wires, like a SCSI 68 pin I think it was, then Apple made the mini-SCSIwith a common ground in a 25 pin D connector.
For a DVD drive, the 40 wire should be fine..
VCRs, cable box, cable mouse, problems
By judybr in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2010, 13:42 -
PC controlling a cable box (USA time warner cable)
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 16:24 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 14:50 -
HDMI cable seems worse than RBG cable
By BroomQueen in forum DVB / IPTVReplies: 7Last Post: 24th Dec 2007, 17:27
