Just 2 questions about it, what are the advantages of using this mode and under the settings for this mode which of the 4 boxes should be ticked
thanks
johnny
In ISO mode you are merely taking an image of the DVD and putting it on on either your HD or a DVDr. I've only tried this when I am ripping the movie-only, and it is shorter than say...1:45 in length. As long as the total size is less than 4.37gb it works fine. When I do it...I have file splitting on auto and have all 4 ticks checked. ISO mode will rip and burn the image for u.
In IFO mode, you can rip the movie only onto your HD and preserve the DVD file structure...ie; ifo, bup and vob files. Then, since most of the flicks I back up are bigger than 4.37gb, I run these files thru DVD2One to compress them to 4.37gb. On the left in the settings area, I have all those 7 boxes checked, and the file splitting set to 1gb. On the right, I have only Stream information checked. This is the technique I use most, since it's fast and easy, and usually I don't care to have all the menus and extras on my backups. If you just want a copy of the movie, this is the one I recommend. Every DVD I've burnt (dozens) using this method has worked.
In FILE mode, I rip the entire DVD and compress it down to 4.37gb using either DVD2One or DVD Shrink. I use this mode if I wish to create a virtual copy of the source DVD...menus, movie, extras and all. In the settings, I have the 4 boxes at the bottom all checked, and select files is set to *all*, but I do NOT check multi angle processing. On the right, I have stream processing set to search at 50,000 sectors.
While I am not an expert at all this, I figgered it might be best to show u what works for me. That way u can play with it and decide for yerself what works best for u on yer system. Hope this helps. -
There are several reasons to rip in ISO mode.
1) If the disc is DVD5 you can use DVD Decrypter to back it up. Choose 'Mode | ISO - Read' to generate an ISO image file, then choose 'Mode | ISO - Write' select and burn the image file. This is also the method I normally use to make copies of my DVDR discs. I can leave the ISO image on the HD and burn as needed.
2) It's one file, instead of several VIDEO_TS folders. If you plan to rip a lot of discs it's easier sorting and storage
3) I can mount the ISO image with Daemon Tools and create a virtual DVD-ROM drive. Then use that a source for editing/backups (eg. DVD Shrink, DVD2One, TMPGenc, etc).
4) Archiving discs.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 11:44 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
DVD Decrypter to ISO file - missing
By mkr10001 in forum DVD RippingReplies: 4Last Post: 5th Jan 2011, 17:55 -
Problems Creating ISO with DVD Fab Decrypter
By ViRaL1 in forum DVD RippingReplies: 1Last Post: 25th Jan 2009, 12:30 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27
