  1. hey all... i have a question...
    i mad a VCD like a year and ahalf ago and fit a whole movie (awsome quality) on a single 80min CD-r.... but i dont remember what setting i had TMPGEnc at.... is there a way i can find out from the VCD?
    thank you all,
    maiof
  2. Search the user guides forum. There is a VERY long thread there about fitting a whole movie on one CD.
    Dec 2002
    Also try KVCD, which is probably what you used.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  4. try looking the folders of the vcd, some programs like dvd2svcd, can put in an info file on the vcd which can hold this type of info
