so im trying to make a custom karaoke DVD and so far it have ripped out the certain songs i wanetd, and have renamed them according to this vobedit guide:
https://www.videohelp.com/forum/userguides/120021.php
but right after i click "join clips", make a new VIDEO_TS folder and try to it as: VOB_01_1.vob file, and when the dialog box pops up and asks: "First VOB-ID" i put "1" just like the guide says and press "OK" . BUT after i press okay nothing happens, like the popup just dissappear and it does do what it is suppose to do (which is show a meter of the progress of VOBEDIT working on my new VOB file)
i'am using VOBEDIT v.06 (i think that's the only version they have)
anyone have any suggestions as what is wrong? also if you need anymore info i can put em up.
THANKS!!![]()
You need to rename the vob's VTS_01_001.VOB etc not VTS_01_1,vob etc. Read the guide again.
yeah i did name it "VTS_01_001.VOB" but when you resave it you have to save it as"VOB_01_1.vob" see:
1. Choose a new folder and name it VIDEO_TS
2. Save the new VOB_01_1.vob file.
thanks for the post though, any other help would be appreciated.
THANKS!!
demuxing VOBs with VobEdit
By siluet in forum Newbie / General discussionsReplies: 13Last Post: 22nd Nov 2012, 16:57 -
VobEdit - won't join vobs
By bahjan in forum Authoring (DVD)Replies: 4Last Post: 6th Feb 2012, 19:29 -
Cannot get VobEdit to work
By Ramon in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2011, 09:13 -
VOB demuxer: PGCDemux or VOBEdit ?
By gabier in forum Video ConversionReplies: 4Last Post: 2nd Dec 2007, 09:01 -
TDA won't display video thumbnails after Vobedit
By spiritgumm in forum Authoring (DVD)Replies: 4Last Post: 25th Aug 2007, 14:35
