hi![]()
just got a film and it's has a cue and bin file, how do I convert to mpg?
Any idea's?
many thanks![]()
Results 1 to 19 of 19
hi
u say to burn the cue file, do u burn this in nero as data or as vcd? If u have two cue files can u merge these and convert in tmpg and out put them in kvcd format?
many thanks -
to make them into KVCD you would have to encode them again and that would make the quality worse. just burn it to 2 seperate discs ( which is normal for vcd/svcd)
use nero.
clicke File---> burn image--> browse to the cue file click open & burn -
Hi,
Do NOT use Nero to burn .bin files, as this software does NOT
properly burn multi-track files--VCD, SVCD, etc.
Instead, use VCDEasy or Alcohol 120%.
c5966 -
A bin is a disk image file and the cue is a text file which contains the information which is needed to burn the bin file correctly. You cannot join cue files but you can use nero (and several other programs) to burn the disk image.Originally Posted by k b"Art is making something out of nothing and selling it." - Frank Zappa
hi
thanks for all your imput, tried with nero and everything works copping the cue file, is there any way of converting the cue file and saving the file ot hard drive in mpg format so i can watch it on pc, or edit the program, like cutting the trailers out at the start of the film with vcd cutter?
many thanks
As suggested....Originally Posted by k b
Also isobuster and daemon tools. Look in the guides section and search each tool for a guide.Originally Posted by Treebeard
And it's the bin you want to convert from, not the cue. The cue is just a small text file, the disk image is in the bin."Art is making something out of nothing and selling it." - Frank Zappa -
in nero, click on file and where it says image or burn image or whatever, click on that and then locate where the file is and then burn it.
Never had a problem. -
In the same vein, do any of you know anything about Nero's "Image Recorder", virtual device, listed when you click "Choose Recorder"?
Does that "burn" from your bin to a HD folder you specify, in MPEG format?
Probably should just try it. I was going to suggest it, but, hey, I don't know.
George -
Oh.
I thought that, since when you do a disk copy, Nero burned an image (nrg file ) to your spec'd folder, this was a diff thing.
Might still give it a try, lotsa space.
Cheers,
George -
Nero only does this with a disk copy if a) you only have one drive or b) you choose not to copy on the fly.
If nero is setup to copy on the fly then you won't get the nrg file in your specified folder. The option to use the image recorder is really for when you don't have any media left and you want to copy the disc to your hard drive to burn later.If in doubt, Google it.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 01:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
