Nero 5.5.10.42 will not recognize my new DVD burner LDW-411S. Has anyone else had this problem and are there any ways to correct? Thanks![]()
Results 1 to 20 of 20
JT
Yes I have the same problem. If you check nero's website this model is not on their supported list....
I've contacted Nero support and am awaiting an answer. I have seen a site where it looks like Nero 6x supports the 411-S.
JT -
What about the stability of 551054? I've seen some issues with some of the later 5.5 releases?
JT -
Never a problem finishing burns,only problem i have with it is generic dvd-r media,up grading to the latest firmware for the 411s fixed a lot of those issues.
Thats a configuration file for more types of burners and the burning parameters.It updates the one already there.
and this why evryone have had trouble with nero and there burnes
Here is changelog. Hmmm... somebody talked about "small" changes...
Features Added
Added support for new features
The default book type for DVD-Video is set to DVD-ROM now to get a higher compatibility with playback devices
Added support for Windows XP for AMD64 in 32-bit emulation mode
Nero Express:
Usage of the CD database in Nero Express is simplified
The "Select files and folder window" will now be placed automatically in a position so that the content of the compilation is more visible
Removed the "New project" entry in the "What do you want to do now?" menu after recording if Nero Express was started from Nero StartSmart
The back button of the compilation page is now hidden if Nero Express was started from Nero StartSmart
Nero Wave Editor:
Added shortcuts and tool tips for all buttons in the toolbar
Nero BackItUp:
Added an option to allow rewritable discs to be erased without
confirmation
Added an option to disable the ejection of the disc after recording
Bug Fixes
Nero Burning ROM / Nero Express:
When burning UDF compilation that contain files larger than 2GB, the caching will not fail anymore
Fixed MPEG video files decoding problems under Windows 98SE and windows NT
Fixed image transfer problems when using NeroNET
Fixed crash when Nero Burning ROM or Nero Express is started from Nero
StartSmart for erasing a disc and no recorder is installed
Improved the error message that appears if an ultra-speed CD-RW is inserted in a recorder which does not support it
Only show option for DVD compilation if a DVD recorder is attached or expert settings are enabled
Fixed displaying of write speeds if a DVD compilation is selected while a CD recorder is the current recorder
Fixed show DVD compilation only if a real DVD recorder is attached
MP4-file extension is now recognized for (S) -VCD compilations
CD copy options for data CDs have been fixed
New GUI for disc label selection for NeroRobo
Added possibility to choose language and keyboard layout for boot disc created with integrated boot image
Fixed erasing speed problem with certain recorders
Nero Burning ROM:
Fixed slightly wrong calculation of size when copying DVDs
In the hard drive backup dialog, changing the disc type will no longer unselect the partition
The save track dialog will now only save tracks in reverse order for drives that need this behavior
Fixed stability problems when loading a VCD compilation containing a "PICTURES" subdirectory
Fixed incorrect display of drive speed and available space in the cache preferences
Nero Express:
Fixed access to the properties of several selected Video-CD pictures through the context menu
Enabled the main window close button in the disc copy page
Enabled text in the dialog for selecting the (S) -VCD menu
Added possibility to use integrated boot image when creating bootable discs
Nero Wave Editor:
Improved the error message that appears in the "Save Tracks as separate files" dialog if the path is not valid
When trying to save a MP3 file with a bitrate that is different from
the original, the original bitrate was incorrectly kept
Nero BackItUp:
Fixed wrong aspect ratio of the background picture when using a
Japanese system
Since only one session is allowed for DVD-R and DVD+R, display a
message if the user tries to write several sessions
Fixed starting backup on blank CD-RW disc, the disc get ejected and application ask for new, blank disc
Fixed drive locking in case CD-RW disc is inserted and "waiting forodisc dialog" appears
Fixed creating a backup with InCD formatted discs fail when more than one disc is used for the backup
Fixed system reboot when inserting second backup disc
Fixed problem with disc not recognized if InCD is installed and disc is an INCD formatted disc
Fixed incorrect time stamps of files on the CD
The BackItUp system tray icon provided context menu only in English
Improved error message that appears when not enough space is available for creating temporary files
Improved error message that appears when the burn process fails becauseof the recorder or the inserted disc
Not all temporary files were deleted when cancelling the burn process
Improved checking of file presence before the burn process starts
Improved detection of locked drive
Fixed handling of menu keyboard shortcuts
Nero SoundTrax:
Fixed stability problems when using learge audio files
Improved error message when opening a npf file which links to some non-existing files
User defined presents are now stored in a different directory than
pre-defined
Logo has been added in the about dialog
Nero StartSmart:
Fixed translation in Windows XP auto play prop-up
__________________
Asus CUSL2-C [I-815PE] \ Intel P-III 733MHz \ 384 Mb SDRAM \ Asus GF4-Ti4600 \ WD 80Gb/8Mb/HDD (0:0) \ Memorex 40Max (0:1) \ Lite-On LDW-411S (1:0) \ Pioneer DVD-106 (1:1)
WinXP Pro SP1 -
I had the same problem, I downloaded the last version ofr Nero 5 and upgraded lie-on firmware, flashing the drive made a big difference in my drives performance.
Release Notes
Version Number: 6.3.0.0
Changes from Nero 6.0.0.28 to 6.3.0.0
Features Added
Added support for new recorders
Nero StartSmart:
Added property pages in the configure part
Added a property page for displaying serial numbers in Nero ProductCenter
Nero SoundTrax:
The last folder used for audio clips will now be remembered
Nero BackItUp:
BackItUp files can now be opened from the Welcome Window.
The dialog that appears when double clicking on an entry in the Last Backups list of the Welcome Window has an additional button for ‘Job’.
Doted lines are now used to mark active items in the two list controls of the Welcome Window.
Cancel button will be turned to “Finish” button on status dialogs.
“Finish” buttons of the Wizard has been changed to “Backup” and “Restore” accordingly with new icons.
The Welcome Page of the wizard will only be displayed in case of a new backup.
A success message box will be displayed when the user clicks on the “Finish” button of the Job Wizard.
An additional status column is available in the Job Window that tells whether the job had been executed successful or not ; with time stamp.
A new “open file dialog” with the last backup list is now available in the Restore Wizard.
The log file of the burn process can be added to the BackItUp Log and old log file can be destroyed using a new options in the preferences.
A new source page has been added in the backup wizard. It can be used in order to continue an old backup more easier.
StartSmart can now launch Backup, Restore or Drive Backup windows directly, in the expert mode.
All items will be selected by default when creating a job from an existing backup.
“Date/Time” text on the finish page of the job wizard has been replaced with “Next run”.
Root icon and drive icons are changed in the restore view.
Hot plugging of recorders is supported.
CD-RW can be erased automatically during a backup process by activating an option in the preferences.
If a recorder is already in use, BackItUp will display a message in the og window and wait.
Added an option in the preferences, to disable disc eject at the end of burn process.
Added support for HD-BURN recorders.
A ReadMe file will be written on every disc, in order to tell where the *.nbi file can be located.
Nero ImageDrive:
Added support for images with sub-channels data
Bug Fixes
Nero Burning ROM:
Fixed recognizing FAT formatted DVD-RAMs in disc info dialog
Fixed “Command sequence error” in case of simulating on DVD-R more than 1GB or in DVD high-compatibility mode
Fixed wrong free capacity calculation when burning to the image recorder
Nero BackItUp:
Fixed backup and restore of a bootable partition is working, but HDD isn't bootable anymore
Fixed restoring of W9x OS in multiple boot environment results in a non bootable OS
Fixed burning on HD-BURN media
Display a warning if the DOS boot image file is not present when performing a drive backup
Fixed wrong message if the disc is not empty
Nero StartSmart:
Fixed not complete German text of StartSmart
Nero API:
Set burn lock when writing in burn-at-once mode
Improvements of error reporting -
Pharlap,
I don't know if your posts are criticisms, or what, but it seem to me if they have made those changes in a week or less, they take their software updates very seriously. Unlike some companies who simply say "Not Supported". Hell, even MS had to be shamed into admitting to a bug. They'd never have repaired it if the "hackers" hadn't pointed it out. Intel and the floating point thing, also.
I don't mind going to the site on a weekly basis and checking.
At least they do improve, not like EZ CD whose V4.5 supported my LiteOn, and 5.0 didn't, but 5.02 did. Whether that was a little bit of spite because LiteOn bundles Nero, I don't know .
Cheers,
George -
yeah they did do all this in the update and i'm not a critic.
these poor bastards are continually readjusting there burn engine to match not the drives but the amount of poor quality discs being made.
seems like no one likes to have standards any more its like when you want 100% beef patty on your burger but you know the bastard is full of soy
Any product similar to the AV Toolbox AP-411 lip-sync corrector?
By svejkovat in forum AudioReplies: 3Last Post: 5th Feb 2012, 13:29 -
Does K-Lite mega Pack support Nero 7?
By Djard in forum Software PlayingReplies: 37Last Post: 20th Sep 2010, 08:10 -
New Lite-on drive being recognized as old lite-on drive
By tlrbjc in forum DVD & Blu-ray WritersReplies: 2Last Post: 23rd Jun 2010, 09:21 -
How do I burn a dvd with nero using ffdshow from k-lite pack
By sxpredman in forum Newbie / General discussionsReplies: 7Last Post: 7th Nov 2009, 02:20 -
Has anyone used Lite-on EZ-Dub
By Ronny G in forum DVD & Blu-ray WritersReplies: 11Last Post: 1st Feb 2008, 02:34
Thanks--the 551054 did the trick!
