I have digital cable, is it possible to run a lead from the digital cable to the pc and watch the channels on the computer? If so, what cable would I need? It would be good to record stuff from the tv on my computer.
I have a tv card.
Thanks![]()
Use a splitter after the cable box, you have all your channels, digitaland non, but you watch the same as the TV and the tuner on the card has to be set to 3 or 4, whichever you use on the TV or VCR, if on is in line.
Split the line before the cable box, you use the card's tuner to watch the non-digital channels. Digital has to go through the box, but you have both options to change as you need.
Probably could do this with a couple A-B switches or something, I just haven't given it any thought.
Cheers,
George
What digital video format compares to Digital 8?
By jungleexplorer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Dec 2009, 15:00 -
Digital optical vs. digital coaxial cord
By coody in forum AudioReplies: 3Last Post: 12th Dec 2009, 08:57 -
Digital tv on pc?
By rcguy1 in forum Newbie / General discussionsReplies: 3Last Post: 13th Mar 2008, 09:23 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54 -
If I buy a 14 inch SDTV with a digital tuner, can i watch digital programs
By davidsama in forum DVB / IPTVReplies: 3Last Post: 6th Sep 2007, 10:25
