anyone compare these 2 products head to head.
I am looking for raw AVI capture.
That gives me a prview and I can set up a timer
Allen
HUH
I thought they were the same product, but just interchangeable names.
FULL NAME: Scenalyzer Live
SHORT NAME: ScLive
Am I missing something here :P -
The main porpouse of Scenalyzer is to divide an already captured AVI-DV file in smaller parts, based on optical scene recognition or date-time changes.
ScenalyzerLive can capture from a DV camera or a DV bridge, split the capture files by optical or date-time or timestamp and can send files back to the DV cam.
It can send DV cam controls like Play, FForward, Rewind etc.
Latest versions also have a timer.
You can judge by yourself because the first is freeware, the second is available as a full-working demo with watermark on output files.
Riccardom -
wow now I am either confused or stupid ...
After looking it seemed to me that in fact they ARE the same SW ...
but now I don't understand Riccardom's reply ...
if it helps I care MORE about the cature in a clena way than the scene splitting.
thanks
Allen -
They are TWO different software.
Scenalyzer does only file splitting.
ScenalyzerLive (ScLive for short) can also capture from tape and record to tape.
Hope it helps
Riccardom
avi to dvd after scenalyzer capture
By robroth in forum Authoring (DVD)Replies: 7Last Post: 9th Jan 2012, 18:23 -
Scenalyzer, optical scene detection
By BTB554 in forum Capturing and VCRReplies: 2Last Post: 16th Jun 2011, 00:48 -
Scenalyzer and Vista
By bobogs in forum Capturing and VCRReplies: 3Last Post: 16th Jul 2007, 22:03 -
Scenalyzer Live 4.0
By Jone.T in forum EditingReplies: 1Last Post: 7th May 2007, 09:38
