I just installed a Sony dru-510 internal in my PC. The PC already had a DVD rom, so I made the sony the master and the DVD rom the slave. Everything works. After a few hours of running the PC. My two drives just stop reading or writing. I reboot the PC and all is well again. Anyone ever see anything like this.
Thank you in advance for the help
Joe
Hmmm
I un-installed INCD from nero and now it has not happened. Could this be the issue? What should I use to write to +RW disks like a floppy. -
It could be the problem - I had the same sort of problem with my setup, and that was down to InCD as well.
As for other forms of packet writing software, try Roxio to see if their plugin is still available - it was part of their Easy CD Creator at one point, and I seem to recall you could download the reader as a plugin. You might find the packet writing side is also available. I am sure someone else on the boards could suggest some packet writing software.
If not, check out the Mount Rainier website - I would expect them to have some links of interest.
Funny Photo
By budwzr in forum Off topicReplies: 5Last Post: 7th Nov 2011, 08:01 -
Trouble with DVD Drives
By Cody_L in forum ComputerReplies: 3Last Post: 25th Dec 2008, 14:06 -
Now This Is Funny
By cracula in forum Off topicReplies: 2Last Post: 20th Mar 2008, 19:29 -
connecting laptop to PC and using both DVD drives
By debrag in forum Media Center PC / MediaCentersReplies: 3Last Post: 4th Oct 2007, 11:20 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 13:13
