Results 1 to 15 of 15
  1. I have just had a new JVC home dvd recorder.i have set it up all ok but i have one question.I am in the process of recording of my analog cam corder onto a dvd-rw disc.I want to then put in into my computer and then edit out stuff i don't need and then burn it back onto DVD.Are there any guides that will give me a walk through and what mode do i have to format the dvd-rw disc in the jvc,is it VR or Video mode
  2. JVC has a dvd recorder? When did this happen?
    Yeah, more info please. Model #, where you bought it, etc ... I've been waiting for JVC to make one.
  4. JVC DRM1SLB
    Playable formats: DVD-Video- DVD-RAM- DVD-RW- DVD-R- CD- Video CD- CD-R/RW- MP3/JPEG Digital Still (CD-R/RW), Recordable formats: DVD-RAM (VR format)- DVD-RW (VR and Video formats)- DVD-R (Video format), Progressive Scan, Digital Direct Progressive Scan Output, Super MPEG Encode Pre-Processor, Block Noise Reduction Circuit, Hadamard Noise Reduction System, Library Database DVD NAVIGATION, DVD Navigation with animated thumbnail (DVD-RAM/DVD-RW VR format), On-Disc Timer Programming (DVD-RAM/DVD-RW VR format), LIVE Memory (Simultaneous Recording) (DVD-RAM), Instant Replay- Quick Skip- Live Check, i.LINK connection (DV Input), I (PAL) tuner, NICAM stereo decoder, 192kHz/24-bit audio D/A Converter , 10-bit/54MHz video D/A Converter , Video Plus+ Deluxe, Auto PDC , T-V Link, High-resolution GUI, NTSC playback on PAL TV.
  5. Thats the one its fab if i could only get the home film onto my computer to edit it
  6. Thats the one its fab if i could only get the home film onto my computer to edit it
  7. where you bought it and for how much ?
  8. I have seen it availabe in the UK for £399.00 in the high street, £299 online.
  9. You can try to look for guides that are talking about DVD-Video to DVD-R. You need to extract mpeg from it or even separate stream for video and audio. Then you can edit mpeg with some Editing tool and re-author it with DVD Authoring tool.
    Best that I know for simple cutting of mpeg2 is Womble MPEG-VCR.
  10. Withdrawn
  11. thanks for the help i printed out the guide that you linked to earlier but it made no mention of my disc not being reconised by windows i'm at the moment scouring everywhere i can think off for a few answers
    Thanks anyway
    Dec 2003
    Right here, right now!
    Hi.
    I'm about to take the plunge and get a JVC DMR1 myself at the end of Jan. ANy comments? Is it good, so far? Have you any complaints, or does it do everything you expected/wanted it to do?
    Any info appreciated.
    Thx
    Troll
    "I've learned that life is one crushing defeat after another, until you just wish Flanders was dead!" --- Homer J. Simpson
  13. so far so good looks and plays brilliant still trying to get to all the different options that it has but overall it does everything that i want it to.
    Good luck with yours
  14. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    It is probably not recognized by windows because the disk is not finalized. If you are using DVD-RW media, you cannot take it elsewhere to work on until it is finalized. Unless DVD recorders don't require that and leave it in a readable state but I doubt it.
  15. Yes you have to finalise it i recorded in video ode and finalised and now i can see and edit them
    Thanks to all that passed on comments
