Hi folks,
This is probably a simple question, but it's something I've not had to do yet.
I'm backing up a DVD that uses LPCM as it's default audio stream but also has 5.1 AC3 as another stream.
I ripped the DVD using SmartRipper 2.41 and then shrunk it using DVD2One choosing the AC3 stream instead of the LPCM (so I'd have more space to get better video quality).
Problem is when I play the backup I don't get any sound until I press the 'Audio' button (ie to tell the player to switch to the AC3 stream).
I noticed that the AC3 stream is on the 0x81 instead of the 0x80 channel.
How do I get it to use the AC3 as default (ie switch it to 0x80) ?
Thanks,
NiVZ.
Results 1 to 1 of 1
Need Help Changing the Default Audio Stream for Hundreds of MKV Files
By ballsoup in forum AudioReplies: 11Last Post: 19th Apr 2016, 16:53 -
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 23:42 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 06:53 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 17:42 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27
