I have a Dell Dimension 8200 computer and I want to upgrade my RAM. It uses RDRAM PC800 Non-ECC. Right now I have two 128mb modules making up 256mb of RAM. I just wanted to know if I add more RAM in the other two open slots do they have to be 128mb also or can I add two 256mb modules?
I think you can add any size, but most people here seem to think 512 is the sweet spot, and you won't get much, if any, improvement by going higher.
As RD is expensive, and Intel has even just about dropped it, maybe you should think with your wallet, not spend more than you have to, as it probably won't transfer to your next machine. -
Originally Posted by FernE97
Your box can run either 400 or 533 FSB...If you're at 2.4 or smaller, think about going to 2.8 for more speed. -
I did an interesting experiment this weekend. I reduced the installed PC 133 RAM from 768 to 512 in one machine and left the other alone. The machines are otherwise identical setups running Win2000 Pro with ATI AIW 9000 Pros.
Both were set to capture football games on Sunday. I'll be damned if I could see a side-by-side difference in performance.
The extra RAM is going to be moved into a Supermicro Dual Slot 1 board I snatched on eBay last week for $1.00! :P
.indolikaa. -
Alright thanks for the responses. I think I'll stick to adding 256mb of ram to make it 512mb since 256mb chips are almost $100 more each.
What processor do you have?
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
