Man, that is a poor design.Originally Posted by arcorob
I confess I didn't look at the manual =
But I ran an s-video cable from my scart connector...
...to the Canopus and yep, you guessed, it wouldn't fit in the front.
I just assumed the front of the unit was for input and the back for output.
Seems logical to me anyway
By the way, when I ran the s-video from the scart adapter in my TV to a scart adpater with composites out, it didn't quite work - I got everything, picture and sound, but it was B&W
Will
Results 31 to 45 of 45
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
One other, un-connected thing...
...I'm still not getting this macrovision and ADVC-100 issue.
I've searched and learnt you hold down the input select for fifteen seconds, right?
Trouble is, when do I do that?
Do I do that before I run the signal through it, ie. before I start my 'capture' program?
When I hold it down with my capture program running its freezes (the software).
I suppose I should...
1) Turn on the ADVC-100
2) Hold down the input select for fifteen seconds
3) Ensure the input select is correct, ie. its set to 'analogue'.
4) Start up Pinnacle Studio
5) 'Capture'
About right folks?
Thanks,
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
As far as I'm aware, the macrovision trick does not work for PAL users.
Regards,
Rob -
Originally Posted by rhegedus
Although I have one of these scart macro-thingies, what do you do for copy-protected video's you're backing up?
I'm gonna play around with my leads tonight (standard composites and this s-video lead that came in the box) and hopefully, by the time top gear starts on Sunday, I'll have the best configuration for comparison.
So, un-edited avi, right?
Don't seem to need anything - I've backed up the whole of Due South season 1 to DVD without any macro problems, but that's probably because it isn't protected.
Regards,
Rob -
OK, but interlacing will look shitty.Originally Posted by Will HayRegards,
Rob -
So what then?Originally Posted by rhegedus
I don't care, whatever...
....TMPGEnc 8000CBR?
No ******* around with colours (in my case) just straight encode.
I'm at home now....
...thanks, but this was no different
Alright, keep your hair on!Originally Posted by Will HayRegards,
Rob -
Damn that is some funny shit but I don't disagree with the Lord of Smurfs nearly enough to warrent a purchase ... too bad their isn't a txpharoah version of those darts though he did seem to fall off the face of the planet we call DVDRHELP.COMOriginally Posted by trevlac
I bet he's a lot closer than people think..........Originally Posted by FulciLives
Regards,
Rob -
Anytime after you turn the power on, then it's good until you shut the power off. You have to do it each time you turn it on. Not sure about that 15 seconds though, seems longer to me, maybe 15 seconds after the lights on the front change. I think I saw somewhere that it's 15 seconds after you see the color bars but you only see those if you have the analog outputs connected to a monitor so that doesn't really help much.Originally Posted by Will Hay
I haven't seen DJRUMPY in a while either. As well as two more people I used to talk with a lot (actually forget their screen names). Of course, not sure I'd want to throw darts at any of them, they've all been a help to me in one way or another. Even Tex, though I still want my blanks back!Originally Posted by FulciLivesWant my help? Ask here! (not via PM!)
I suspect this is a PAL-only feature - I tried doing this last night (i.e. hooking up my RCA composite video plug to the Canopus supplied adapter, and connecting the S-VHS-like plug on the adapter into the back of the ADVC-100), but no video registered on my capture program (Ulead Movie Factory 2). When I reverted to my old configuration - RCA composite to ADVC-100 - my capture program registered incoming video again.The day I first tested my ADVC i was very disappointed. I was using a straight RCA (L R audio and VIdeo ) plugs and experienced the same color bleed you mentioned. I said "This is crap". So then I noticed the small supplied adapter plug and said "Okay, i'll try it" well, I hooked it to the RCA Video lead then went to plug it in to the ADVC.
Now you know, the AUDIO plugs are in the front for INPUT. SO seeing the S-VIDEO connection in the front I tried to connect. It would not plug in. I looked at the pins, looked at the plug and said "This can't be" I said "Dang, they sent the wrong plug"
Took me a half hour of stumbling before I finally caught on (In the manul ) that the S-VIDEO IN is in the back (poor design.....)
DVP3100V - composite/SCART signal correction
By Annihlator in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Dec 2010, 05:56 -
Cable Length vs Signal Loss
By nkordyjaka in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 11th Oct 2010, 10:31 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
How to Split NTSC Composite Video signal ?
By SingSing in forum RestorationReplies: 16Last Post: 26th Jan 2009, 11:50 -
PixelView PlayTVpro: Composite video signal not captured
By faisalshafait in forum Capturing and VCRReplies: 0Last Post: 1st Nov 2007, 15:42
