I've some flash file with background music which can't be seperated. Is there any tool available which can extract the music or songs from such file or simply what is being played at background can be captured and saved in to mp3 or wav file. Kindly help please
Does your sound card have the ability to record "what it hears". This would probably be the best way of extracting the audio. Just play the file and whatever is being played through the sound card will get recorded.
Or since its a flash and if you had Macromedia Flash program, you could maybe open it in there and extract it.
I would go with the "what it hears" method though. Lots easier and you can probably specify what type of file you want it saved as. My Audigy Platinum can do it. Not too sure about yours though.
Good Luck
HatzLoves the funeral of hearts..... -
No more cross posting, one topic is enough. Other topics closed. If you think you are in the wrong forum (and maybe you are), ask a mod to move your post.
You might also try and think of better topic titles.doesnt't really say much about what you want/need.Kindly help me please
Kindly advise on the best mpeg editing software. Thanks.
By seymoria in forum EditingReplies: 18Last Post: 7th Dec 2007, 08:25 -
Two sets of Subtitles In Video Kindly Help?
By zephyr360 in forum SubtitleReplies: 1Last Post: 14th Jul 2007, 15:45
