    Nov 2003
    the dark side of the moon
    I need to convert IFO files to some sort of media files so Edit Studio 4 will read them how do I do this?I have dvd shrink and dvdlab.I am trying to put all of the best fight scenes for different movies all on one dvd. The files say VIDEO-TS IFO file and VTS_01-0 IFO file.I need to use Edit Studio 4 to put a transition between scenes.
    Thanks stinkfist
  2. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    You got any VOB files to go with those IFO files,
    AFAIK The IFO's hold INFormation about the media thats in the VOB files (Video OBjects i think)
    you will need both b4 you can do what you want to do
    Nov 2003
    No VOB files but there are some BUP files.
    Thanks stinkfist
  4. Member Sifaga's Avatar
    Aug 2003
    AFAIK BUP's are just the backups of the IFO files .
    you need the VOB's
    Nov 2003
    I am using dvd shrink to get the scenes and this is what it gives me IFO and BUP how do I make them VOBs.
    Thanks stinkfist
