    Dec 2003
    I just coded an svcd and its like 1.49gig I believe. The problem I have is I'm going to split it in half so fit on two disc. But when I use tempge and cut it in half, the file from each one the sound is cut at the very end of each. Lets say like on cd 1 at the very end the sound drops video continues, this also goes for cd 2. I'm not sure how to fix this and any help would be appreciated.
  2. I've noticed this also and I've had no luck disabling it. Since the audio stops at the exact point where it was split, I always just thought of it as an outro or something, but if you are saying it does it on Disc 2 also, I don't know. I've never noticed that because the end of Disc 2 is usually the credits (which I don't really watch). I just usually make sure that I start Disc 2 at the exact point that I ended Disc 1 and I have never had a problem with losing anything. When you do Disc 2, do you make sure that it goes to "last" instead of a specific time?
