  1. Good Evening!
    Indolikaa likes to capture all audio for DVD use as PCM and then conduct the appropriate post-processing, if any is required. Many discs are made with a straight PCM/WAV soundtrack; Indolikaa's ears are in much better shape than his eyes after 31 years!
    However, after downloading the trial version of MPEG-VCR for testing, I have discovered that while their software will allow the importation of LPCM audio streams, it will always encode them to either Layer-I or Layer-II once editing is complete. I e-mailed their support team and they answered back (within 1 business day, and for a trial user, I might add) that this 'limitation' will be removed in the future.
    If I capture a WAV that is coded to MP2 and then transcoded back into WAV, how much quality will be lost in the process? I am only assuming there is a loss because MPEG itself is a lossy compression scheme and one cannot de-MPEG without having to guess (to a certain degree) what the original WAV file looked like.
    Your time and input is appreciated.
    .indolikaa.
    The Audiophile
  2. Originally Posted by indolikaa
    .indolikaa.
    The Audiophile
    If you really are an Audiophile, then it is your ears that are the best judge of this.
    On a slightly more technical side, it also depends on the bitrate used when encoding the wav to mp2. Higher bitrate == higher quality (in general, bad encoders can ruin this theory), so if you can, set your software to use the highest bitrate possible for minimum quality loss.
  3. Member Cornucopia's Avatar
    1st-Loss is loss. Once it's gone, you can't get it back. Hopefully, you will be encoding at a high enough bitrate to where the loss won't be noticeable.
    2nd-If you know you'll be going back to WAV at some point, why not just keep the original WAV file around. Build up a folder of those that you use and back 'em up to a DVD as Data files, then re-use them when your software supports it.
    HTH,
  4. Originally Posted by bugster
    Hardly. I reserve the area underneath my name for smart-ass comments related to the posting in question.
    @ bugster/Cornucopia
    Both replies are duly noted. Thank you.
  5. Originally Posted by indolikaa
    Just the area underneath your name
  6. Originally Posted by bugster
    Are you suggesting that Indolikaa would fill a thread posting with rhetorical nonsense and smart-ass comments?
    Oh, wait. That describes about 90% of my posts, doesn't it?
    .indolikaa.
    Relax, Laughing is OK
