I don't have the best sound card and when I listen carefully I can hear hiss and other noise. Are there any freeware that can help?
Are you sure this isn't your speakers? My speakers also hiss and buzz a tiny bit. It's only natural for actively amplified speakers to do that. Could be interferance from the power supply or other wires winding around the audio cables.
Or, do you mean to say you can hear the hiss over the music you are playing?
If that's the case, what speakers and soundcard are you using?
CobraDMX -
The problem is with my onboard sound card. I hear hiss and buzz when I play back my own video captures (off satellite tv). There is no hiss and buz when I play back audio cds.
Are there any software noise reduction that works in real time captures? -
posted in error, sorry.
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Converting and removing noise/hiss at the same time
By Teac23 in forum Video ConversionReplies: 3Last Post: 21st Jun 2010, 12:35 -
Add silence to beginning of track
By CSULB71 in forum AudioReplies: 3Last Post: 10th May 2010, 16:04 -
Need advice; using Audition to remove hiss (and noise?)...
By takearushfan in forum RestorationReplies: 22Last Post: 4th May 2010, 04:29 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 04:54 -
NON-COPYRIGHTED silence?
By saturndude in forum Newbie / General discussionsReplies: 15Last Post: 29th Jul 2007, 17:55
