Hi all,
I was hoping that someone could point me in the direction of a jpeg to mgeg converter? The jpeg files are obtained from a digit camera and I would like to convert them to vcd via my Neru burn software that accepts mpeg only. Freeware would be nice...
mjh
you can convert them using tmpg, but it's gonna look blurry and shit unless you increase the resolution (if your standalone player supports it).
Normally when I encode pics w/ TMPGenc I use 704x480, this is a supported resoultion. 720x480 is not for some off reason?
Depending on your source resolution you might want to add borders to the left/right to keep the image from getting squeezed. -
I posted something on this here: http://www.vcdhelp.com/phpBB/viewtopic.php?topic=38352&forum=1
Take note of the aspect ratio issue -- or else your pictures will look "off" on your TV.
Regards.
Michael Tam
w: Morsels of Evidence
MPEG I-frames to JPEG
By bluethunder888 in forum ProgrammingReplies: 13Last Post: 9th Jul 2011, 17:54 -
working with universal M-JPEG (not MPEG) HD codec
By devdev in forum EditingReplies: 0Last Post: 8th Jan 2010, 06:58 -
jpeg to word converter
By sumeshkri in forum ComputerReplies: 2Last Post: 26th Aug 2008, 23:57 -
Screensaver for WMV,MPEG-2 clips and JPEG pics
By rch15 in forum Software PlayingReplies: 0Last Post: 18th Aug 2008, 00:14 -
How do I convert Motion JPEG to MPEG-1?
By TheEvilHammer in forum Video ConversionReplies: 6Last Post: 18th Oct 2007, 18:58
