Hi all (again),
Right ive still got a problem with audio sync when encoding avi files.
I just encoded an mpg file with "tmpgen" and then used "tmpgen dvd author" to author and burn an the result was great no audio sync problems what so ever.
But i did an avi file exactly the same way but got the sync problem.....plays very well but the audio goes out of sync after about 40 mins.
Now theres a few things i think might be the problem but need advice.
1) ive heard that tmpgen cant handle vbr audio....how can i find out if my avi files are vbr ?
2) the avi's may not be pal "as i live in england" if there not does this make any difference ?.....if so how do i find out what format they are?
3) ive heard that the problem maybe corrupt frames,so i did a check and only one file has corrupt frames but could not find the badframes log ?
4)is the problem got anything to do with codecs ?....i have xvid and nimo codec pack.
I really need to sort this problem out as ive read so many suggestions but none as gotten rid of this problem.
Thanks for any advice.![]()
It dosnt matter if your black white yellow brown it dosnt matter where your coming from this is a world about unity for us to keep going on and going on strong.......PEACE !!
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
How to author a god damn dvd with subtitles?!
By Redhotpengy in forum MacReplies: 7Last Post: 7th Jan 2012, 05:51 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
VHS to DVD (Damn Macrovision)
By ctdvd in forum Capturing and VCRReplies: 15Last Post: 3rd Apr 2010, 20:00 -
damn Subtitles can't be burned ?!
By insext in forum ffmpegX general discussionReplies: 19Last Post: 13th Dec 2008, 06:49
