Never did get a reply to my question in another post about an eject button I found on my DVD standalone recorder. I discovered one on my cyberhome when a disk got stuck and would not eject. Was just curious if any other models have one. Mine paid off, but I found it the hard way. Opened it up.
If you open up the tray, remove any disc, you might see an eject button on the front of the recorder. I had to use a flashlight to see it. Then I noticed the slot on the bottom of the unit giving access to the button. I will probally modify a used popcycle stick to reach it, buy slightly bending a little 30 degree angle on the tip of the stick.
Panasonic AG-1970 Eject button
By aliasnexus0 in forum RestorationReplies: 1Last Post: 30th Jun 2010, 14:32 -
DVD Player won't eject. Philips DVP5992/37
By pops49 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Sep 2009, 16:59 -
DVD tray won't eject...
By zowiemagic in forum DVD & Blu-ray RecordersReplies: 6Last Post: 25th Dec 2007, 15:03 -
Samsung DVDRW Drive Won't Eject
By 888888 in forum DVD & Blu-ray WritersReplies: 4Last Post: 5th Nov 2007, 19:27 -
burning error/disk eject
By djspud in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Jul 2007, 14:15
