I was just wondering how to use DVDInfoPro to check a copy of a DVD for errors??? Thanks
From memory, you just select the CD or DVD burning drive at the bottom of the window. On top of the window, click on the icon that shows a magnifying glass. Then click start at the bottom of the window.
Thanks, That was to easy. I was looking for something more difficult that is why I could not find it... :P
Thanks again
Need coding info
By John O. in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Aug 2010, 15:29 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
info on nashi
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2007, 05:22 -
firewire info
By psxiso in forum Capturing and VCRReplies: 5Last Post: 15th Jul 2007, 07:08 -
HD DVD info
By skaterboii in forum Newbie / General discussionsReplies: 3Last Post: 27th May 2007, 05:43
