I have bin/cue files obtaines from a test sample https://www.videohelp.com/svcd.htm
I have extracted the files and have followed the steps with Isobuster BIN/CUE SVCD to MPG
Install and run Isobuster.
Select File->Open Image File and open the CUE file.
Click on the MPEG2 folder.
Select all mpg files and right click and select Extract but filter only M2F2 Mpg frames.
Save the new file as filename.mpg. Then tried to load it in Nero Express to burn to SVCD but it says
The video file is not S VCD compliant
To autimatically re-encode the video to SVCD format using Nero MPEG-2 /SVCD pluggin, please visit our webshop and find more about the high quality encoder
OR a disk image of a SVCD
bin/cue file are pre compiled raw images of a CD CONTAINING an MPEG2
do this
Get Daemon tools installed
it makes a fake CD drive.
load your bin cue into it and you will have a new drive on your computer
with a SVCD in it which you can examine and play
then you might believe me -
Or just get Fireburner or Alcohol 120% and simply burn it.
you can use Daemon tools to mount the cue/bin and copy CD from Virtual drive > CDRW (although I don't see the point). -
Sorry im new to this, i didn't explain it properly. I would like to have a SVCD to test my standalone DVD player to see if it plays them. I found the cue/bin files and want to burn them to a svcd. How would i do that? It wont let me burn the cue/bin files to svcd.
I dont think my burn tool Nero can burn to SVCD. Are there any free tools that can? -
1. Load NERO and close the wizard.
2. Go to FILE (Top left of Nero Window) and selct BURN IMAGE.
3. Browse to the location of the BIN/CUE file.
4. Select the CUE file.
5. Burn it to a CD.
That's it. The BIN/CUE file is a SVCD image already formatted and ready to burn. No need to extract the MPEG and re-burn to SVCD. It is already an SVCD. REALLY !!!
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 01:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
