Hello.
I have been using Premiere 6.5 for a long time now, but recently I had to reinstall XP, and now I can't get my Firewire card to function propertly in Adobe Premiere. I have a standard firewire card (NEC OHCI 1394), and I haven't done any changes what so ever to it, so I can't understand why it isn't working like it should do in Premiere. When I try to capture (I have a Sony TRV-18E by the way), I do get picture, but no sound...and I always get this error message when I start Adobe Premiere:
('Error connecting to Microsoft(TM) DV Drivers' Premiere was unable to connect to the native Microsoft(TM) DV support on this machine. This setting was designed to only work with an OHCI IEEE1394 (Firewire, iLink) card with an approved Microsoft DV driver...blah blah blah....)
After this I have in my frustation formated the computer, reinstalled windows and adobe several times, but the same error message always comes up.
I know its not the firewire card, because I took it out and tried it on my friend's computer and it worked fine. So what I want to know....WHAT TO DO?!?![]()
If anyone had a similar problem and know the solution, please help!!
Thanks,
U could try re-installing DirectX or
In Device Manager see if the Driver powering the card is a Texas Instraments OHCI or just a plain OHCI driver. I've found some cards which dont use TI chipsets work badly when the TI driver is loaded. -
Foo: Yeah, I hate winbloze. But I'm too lazy to get a better system/computer.
Greg12: Like I said, I have re-installed windows several times (and therefore directx). The firewire card is a plain OHCI card, its not texas its nec. -
try to
1-uninstall the software and drives, remove the card
2-shutdown the pc wait 1 min
3-turn on the pc and shutdown again
4-install the card and turn on again
sometimes works when i have a prob
Black screen system32\DRIVERS\pci.sys Error with XP
By neworldman in forum ComputerReplies: 1Last Post: 8th Dec 2010, 16:34 -
microsoft visual c++ debug library error
By rrtbusa in forum ComputerReplies: 5Last Post: 12th Oct 2009, 09:15 -
Connecting tv to PC without a TV-out?
By andyr74 in forum Media Center PC / MediaCentersReplies: 2Last Post: 27th Dec 2007, 00:48 -
Microsoft: Free and open source software violates 235 Microsoft patents
By rkr1958 in forum ComputerReplies: 32Last Post: 12th Jun 2007, 00:36 -
Microsoft Debug Error DAMAGE: after Normal block (#39)
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 24th May 2007, 10:59
