Is there some method or program that can tell me what codecs are installed on my computer and when they were installed?
Depending on your operating system, but you can try by going into:
Control Panel
Multimedia, or Sound and multimedia
go to the last tab (I don't remember what it is called under w98, or ME)
Look up the Video Codecs listed there.
If you are using W2K (which I doubt)last tab is called Hardware, click on it, and then go to the bottom of the list there is Video codecs.
Alfonso -
most codec info can be viewed with
control panel, sounds and multimedia, devices and then you can see the codecs listed uder audio and videocompression codecs.
However not all are listed here, some dvd, wdm driver/codecs (cinemaster etc)are not here but come under the dll files in system.
scattergun
what codecs do I need?
By johnsees in forum Newbie / General discussionsReplies: 19Last Post: 23rd Jul 2010, 08:53 -
Codecs
By Nekias1 in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2009, 13:00 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
