Hi everyone. I'm trying to get the best audio possible on my encodes from HQ VHS tapes, and I had a couple of questions. I'm using TMPGEnc to encode from AVIs produced by an ADVC-100.
Right now, I'm using the tooLame plugin for MPEG1-layer 2 384kbps. Would audio fidelity be much better if I used the LPCM stream? If so, how can I synch it up back with the video (since TMPEGen produces two different files if you select LPCM). I tried just using "replace audio" in Ulead MF2, but it wasn't quite right. Do you need particular software to produce a single file containing the audio and video, and in sync? I guess this also goes for any AC3 files I might make out of the LPCM stream. Sorry if it's a dumb question, but I haven't seen anywhere how to do it!
Thanks,
Jerry
Results 1 to 1 of 1
Which camcorder (newbie question)
By CliveJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 19th Aug 2011, 12:36 -
Newbie codec question
By fotoruss in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 21:47 -
Newbie with a question on using Avidemux
By The Monarch in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 22:25 -
Newbie question about learning
By Tundra Trout in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 17:41 -
Newbie question about the audio sounds of my PC
By jeanpave in forum AudioReplies: 5Last Post: 12th Sep 2007, 00:32
