I have downloaded a film and the only program it will play is VideoLAN. I want to put it on DVD but when I try to split the audio in VirtualDUB it says there is no decompressor avaliable and Goldwave will not even look at the file. Any ideas on how I can create an audio file?![]()
the codec is ac3 (0x2000) Dolby Laboratories, Inc, how do I go about getting this codec?
If you convert AVI files that contain AC3 audio, you will find the VirtualDUB mod version pretty useful. It can read MPEG-2 and AC3 encoded files. Normally used for opening VOB or MPG files, it is also suitable for DivX/Xvid with AC3 audio files.Originally Posted by Burnman
The best way to convert to DVD is to extract the audio in uncompressed WAV format and the video separatelly (don't use direct stream copy, the codecs used sometimes by other people don't work well with MPEG encoders) using a different video codec. If you are not tight in disk space, use Hufyuv. It will not degrade video quality in the intermediate step.The more I learn, the more I come to realize how little it is I know.
converting WAV to MP3 and preserving timecode
By soundie in forum AudioReplies: 3Last Post: 2nd Jul 2010, 13:33 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
Converting WAV to MP3
By igorek in forum AudioReplies: 5Last Post: 1st Jun 2008, 20:25 -
Converting WAV to AAC -- am looking for some howto methods, etc.
By vhelp in forum AudioReplies: 7Last Post: 12th Apr 2008, 14:55 -
Converting .FLV audio to .WAV
By socool135 in forum AudioReplies: 1Last Post: 20th Feb 2008, 19:24
