  1. I have been using Nero 6.0.0.19 for some time now, and it has worked fine. I have burned some avi files do video cd and had no problems untill I had a tv-program I wanted to burn that is over 80 mins long. I put a cdr in that has room for 800mb/90min, but it seems that when I use Nero Start Smart that it does not recognize the size. Does anyone know how I alter the standard = make Nero understand the size, that there actually is room. I tried to use Nero Burning Rom to do the same, as I remember, it actually checks the size of an empty cdr, but have not succeeded as I can't drag and drop the file over as I have done with music hundreds of times.
    Please advise.
  2. use nero burning rom, go to file>preferences then click on expert tab.
    Then click enable overburn and type in the cd length in minutes.
    I got Ice Age (about 82 mins) onto a 80 minute cd once (all cd's have a 'bit extra'), but if you have a 90min cd you are easily covered
