I'm a newbie at this video stuff so forgive me if I don't have the lingo down. I've been trying for weeks now to use quicktime pro (and even compressor) to take an mpeg2 file and reencode it as mpeg2 but at a lower bit rate. The quality I get is very good (better than results from experimenting with dvd2onex) and I thought it would be a simple matter to put everything back together with DVD studio pro. However, no matter what I try, the reencoded video is shorter than the original and is out of sync with the audio when I put it back together.
I'm guessing that I could separate the six channels of the AC3 file and use quicktime pro to add it "scaled" to the video and then extract the audio and put it back together with a.pack, but there must be better way. I must be doing something wrong in the reencoding step, but I've run out of ideas.
Any hints/suggestions would be greatly appreciated. Thanks in advance.
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
Reencoding VC-1 WMV at lower bitrate
By casimps1 in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 22:34 -
Is low bit rate mpeg2 (1200kbps) compatible with all DVD players?
By jimdagys in forum Newbie / General discussionsReplies: 7Last Post: 18th Jan 2008, 07:49 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
Lower Wma Bit rate
By hocapoca in forum AudioReplies: 3Last Post: 26th Aug 2007, 21:04
