I have recently purchased a DVD recorder and wonder what software package would be the best solution for adding menus? The recorder works great but the menus could use some work! I tried TMPEGenc DVD Author, but it appears as if you have to import the DVD video (create an mpeg) then add menus and re-burn. I was looking more for something that would only alter the menus, and not force me into importing the video from the disc. I guess basically i want something that will open and edit DVD+RW's directly. Is this possible??? I am sure many of you out there are doing this very thing, and would like to know how you go about doing this.
Thanks,
gpwake!
Results 1 to 9 of 9
dvds are not like cds. you cannot make a compilation disk.
once they are burnt they are finalised. Once this is done you cannot
editthat disk without ripping to your harddrive and rebburning -
Really...I just got Ulead Movie Factory 2 which allows me to edit a DVD! It doesn't like the AC-3 audio though, which causes no problem as long as i don't try to import the video. I can successfully add my own menus, then re-burn the menus to the DVD+RW disc.
Thanks though,
gpwake! -
you still have to reburn the whole dvd again. you cannnot just pick which part of a rw you would like to erase ie the menus.
I-C what you mean, but when burning the disc for the second time with the new menu's it only takes like 1 minute! While burning it says updating menu information....That lead me to believe that only the menus were being written. If it were re-writing the whole disk it would take way longer than 1 minute as there is approx 1 hour of video footage right???Originally Posted by dougy69
With DVD MovieFactory, you can modify existing videos and menus in a DVD+R/RW, DVD-R/RW or miniDVD disc using a compatible disc burner.
Edit Disc Allows you to re-edit video or menu files in a DVD+R/RW, DVD-R/RW, or mini-DVD discs that have already been burned. If the disc was created in DVD-Video re-editable format, you can modify the previously created menu or add/delete videos directly to the disc without copying the file to your hard disk. Specify the drive that contains the file to be re-edited in Disc drive.
This is from the DVD MovieFactory help files. -
So if i decide to sue for false advertising you would back me up in court???Originally Posted by FOO
DVD Flick- Disc Menu Navigation Question
By ellentk in forum Authoring (DVD)Replies: 0Last Post: 25th Aug 2011, 10:00 -
Pinnacle 12 DVD Menu question
By thejigsawman in forum Newbie / General discussionsReplies: 2Last Post: 21st Feb 2011, 13:39 -
newbie dvd menu question
By mikeoliver1313 in forum Newbie / General discussionsReplies: 1Last Post: 2nd May 2008, 06:05 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 14:16 -
question about dvd menu button
By HDMI in forum Authoring (DVD)Replies: 5Last Post: 23rd Jun 2007, 23:06
