What's the most reliable Packet Writing software for DVD-RW? I've used Direct-CD/Drag-to-Disc for years... but it does not perform well.
2 DVD, or not 2 DVD, that is the question.
I've used Nero's InCD and B's Clip. Both seem to work fine. I can attest to the fact that they both work better than Adaptec. Much better.
Thanks for your input. I'm dumping Roxio! Going with Nero's InCD. I like Nero's other products.
Ran into a new Roxio problem. When un-installing, Roxio's un-installer crashed. So, I had to manually remove most of the Roxio Software. I deleted it's folders and all of the registry entries I could find. Did a re-boot, everything looked fine. Installed InCD, did the required re-boot, Now windows will not load, it seems to "get stuck" while trying to load InCD. Had to start in safe mode, remove InCD, reboot to load windows. Is there something still installed from Roxio? Hmmm.... I tried re-installing Roxio, thinking that I could then remove it, without a crash, but, Roxio now will not install, it tells me that a previous install is in progress and will not continue. Any ideas? Thanks!2 DVD, or not 2 DVD, that is the question. -
Try Registry Doctor or a similar prog that fixes reg entries, also Norton SystemWorks 2004 has some good repair functions.
Would Appreciate Recommendation for Reliable DVD+RW
By Novice20 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jan 2012, 23:12 -
Need Reliable MPEG-2 Editing Software ...
By cyberboy in forum EditingReplies: 2Last Post: 15th Nov 2008, 02:04 -
Any free, good, reliable software for video streaming capture?
By rob1974 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2007, 16:26 -
Is there a reliable DVD-R DL Disc?
By faramith in forum MediaReplies: 10Last Post: 20th Aug 2007, 13:19 -
Is DVD-RW backup reliable?
By bevills1 in forum ComputerReplies: 15Last Post: 21st Jun 2007, 16:01
