i have a captured movie that is mpeg-2 and when i author it to vob to burn it to dvd the audio gets out of sink. when i vue thw mpwg files the audio is ok , but after the conversion it is off. it is off at the start and doesnt seem to get any worse. i am useing tmpegnc dvd author 1.5.15.49. thanks
Results 1 to 9 of 9
more than likely your video is out of sync with the audio already. Even though it will play Ok on your computer, it may still be out of sync (computers will correct for alot of the problems).
What type of sync are you having? 2-3 seconds before/after OR gradual in and out of sync.
If it is continual 2-3 seconds before/after, use TMPGENC (not author) to split the video and audio (demux), cut or add the amount that it is off, and then mux it back together.
If it is a gradual in and out. You out to just rerip the audio and reconvert the audio and then mux it up. It may have been a bad setting. -
thanks mac. i now have 2 files and i am lost. where do i cut the audio or video. it is a constant 2 or 3 sec. i need to know how to put it back together.
thanks jim -
bubba,
You are converting from video tape I assume? You probably have a poor source tape, and what is actually happening is that you are dropping video frames while capturing while NOT dropping audio frames. This will cause your audio/video to be in perfect sync at the beginning, but will gradually get out of sync by time goes on. The reason your file plays ok on the computer is that padding is added to compensate for the dropped video frames, but once you try to edit, remux or author, the padding is lost.
Unfortunately, there is really NO proper fix for a gradually out of sync file. It's not worth your time to even try unless the audio and video are just out by the same amount from start to finish. There is no authoring software I am aware of that will keep the padding, so with at least this particular file, once you author it, you are going to lose padding and therefor sync. -
it is a movie from dss. the timming seems to be off from the very start and doesnt get any worse. i dont think it is frame drop.
Is it recorded on a PVR perhaps? At any rate, if it is off the same amount from start to finish, that kind of audio sync problem can be fixed. Check the "how too" section of the forum.
it is recorded from a video capture card . it is in 5 files. it seems to be off from start to finish. i will try to fix when i get more time.
Normalize Audio with TMPGEnc DVD Author 3?
By jonas more in forum AudioReplies: 2Last Post: 16th Oct 2008, 21:10 -
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 11:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
TMPGEnc DVD Author 3 - Playback problem, Help!
By cbales_24 in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 16:29 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43
